How do you check a coil?
Old Jun 16, 2010 | 08:57 PM
90RED3rdGEN's Avatar
Ran before the heads came off. Re-assembled & now no spark from the coil. Any ideas?
Old Jun 16, 2010 | 10:12 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: How do you check a coil?
I BELIEVE for
internal coil----( coil in cap )
pull a plug & re-attach the wire, lean it ( plug & wire ) against a head or the block, & watch for a nice blue spark to jump the gap while someone cranks the engine.
KEEP AWAY from fuel system!!
crank the motor for a few seconds.
external coil--
pull the coil wire from distributor,
lean it against a head or the block, watch for a nice blue spark to jump the gap.
DO NOT TOUCH while cranking-- you will be thrown across the garage!!
Before you do this, verify your plugs are gapped correctly.
( edit )
Also, make sure the distributor is plugged in correctly for internal coil.
Make sure coil is wired correctly for external coil.
92camaroJoe
Jul 29, 2023 07:57 PM
mddaniel
Sep 8, 2015 05:16 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
92camaroJoe
Aug 13, 2015 06:07 AM
