Help me identifiy these engine parts?
Old Jun 16, 2010 | 11:23 AM
J0hn_J0hn08's Avatar
Car: 1986 Iroc-Z
Engine: 355
hey guys well i bought my car not long ago and the previous owner didn't really take care of his car.
I found pieces in the engine missing and things disconnected.
Can anybody help me identify the parts highlighted red so i can replace them?
im a noob when it comes to technical engine stuff so any info on what each part does would be great and if anything could break if i continue to run the car as is.
Old Jun 16, 2010 | 11:36 AM
92RSMoneypit's Avatar
Car: 92 camaro B4C
Transmission: t5
Re: Help me identifiy these engine parts?
The missing hose is called a heat riser tube it part of your emissions.
The hose that you say is crusty is the upper radiator hose you should replace the upper and lower at the same time.
The other thing you said was disconnected is hard to tell from your picture need a better picture.
Old Jun 16, 2010 | 05:33 PM
Car: 1986 Iroc-Z
Engine: 355
Heres a better look.. it was originally disconnected for a long time..but i got it hooked back up, im curious as to what it does exactly
Old Jun 16, 2010 | 06:49 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Crankcase breather. Reuses crankcase emissions rather than venting to atmosphere. Rust on serpentine belt pulleys makes it look like it sat without running for awhile. Replace any water or heater hoses that have soft spots. May also want to replace that belt if it is cracked or worn. Looks like the same 5.0 TBI engine I have. Lots of great info on TGO to help you out. Welcome!
Old Jun 16, 2010 | 07:18 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Is there to put hot air into the engine for faster warm up on cold start.Is operated by the vac pot shown on top of air snorkel
That hose from air cleaner is the supply air for PCV system.
Vac sucks the fumes out of engine from drv side rocker cover through the hose shown in top pic
Old Jun 17, 2010 | 12:06 AM
Car: 1986 Iroc-Z
Engine: 355
Thanks for the help and welcome guys.
Gonna try to get these parts asap even if i can run without them.
Azrael91966669
25
Jun 20, 2017 04:04 AM
italiano67
Dec 11, 2016 09:21 AM
Caspar
Jun 19, 2016 11:19 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
1nastygta
Aug 8, 2015 07:38 PM
