Building An Engine-Need advice
Old Jun 17, 2010 | 07:47 PM
Tunahead's Avatar
Ok, here's what I have:
355 shortblock (older style block), flat tops w/valve reliefs
Vortec heads, with upgraded springs
Weiand Stealth Ram 7542 TPI for vortec heads
Using other tpi parts for now from an 89 GTA (305) (rails, injectors, throttle body)
I have a computer from an 89 vette
I have a hypertech chip
Painless wire harness to put this in a 71 Camaro, with a 5-speed manual behind it.
Im considering a cam from a friend to save a bit of cash if it will work:
Duration at 050 inch Lift224 int./234 exh.
0.465 int./0.488 exh. lift
Lobe Separation (degrees)114
Not sure if this cam will work but I was looking for some input from the members here. Any and all discussion is appreciated!!
92firebirdguy
Sep 1, 2016 07:53 AM
Jorlain
Oct 8, 2015 01:57 AM
MSRed91Camaro
Oct 6, 2015 01:56 PM
89 formula TPI
Sep 8, 2015 08:00 PM
mrdevontay
Sep 2, 2015 08:04 PM
