Engine spudder
Old Jun 17, 2010 | 11:44 PM
musclecars90's Avatar
Car: 1986 Iroc Camaro
Engine: 305 5.0L
Transmission: 700 R4
Engine spudder
I have an 86 Iroc with a 305 in it. On my way home tonight I got a service engine light that came on so I'm like no biggy I will pull the code wen I get home. Well I barly made it home, 10 min after it started to spudder every time I hit the gas. Finally I got it home and pulled the codes. Code 21 Throttle position sensor (TPS) - signal voltage is high and code 33 Mass air flow (MAF) sensor - signal voltage or frequency is high during engine idle.
Any ideas on the first thing I should do. Any help I would appreciate.
Old Jun 18, 2010 | 03:18 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Engine spudder
My car isn't TBI or TPI but I'd start with replacing your MAF and TPS sensors.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
