Where is the oil sending unit on a 92 RS???
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
Where is it? I know it's not by the distributor. Where is it? Anyone got a pic or a good desc. Of where it is? Please go into detail of where it is
Car: 92 RS, 89 Formula, 84 Iroc
Engine: Carb 350, TPI 305, TBD
Transmission: T-5, 700r4, TBD
Axle/Gears: 3.42 Posi, 3.08 Posi, Moser 3.73
Re: Where is the oil sending unit on a 92 RS???
Should be right above the oil filter.
Axle/Gears: G92
Ok thanks
Last edited by david068513; Jun 22, 2010 at 12:45 AM. Reason: I'm a idiot and can't read
Car: 84 z28 h.o./ 92 rs
Engine: 305 h/o /3.1 v6
Transmission: hybird turbo 350/t5 bog warner
Axle/Gears: non posi 3.73 / ls 3.42
on my 92 rs was attached to my oil filter housing (the metal thing you screw the oil filter on )
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Right above the oil filter as mentioned. Will have a 3 wire plug attached, one red wire, one orange wire, and a third. The red and orange run the fuel pump, the third sends signal to the guage. Here's a pic of one:
http://www.autozone.com/autozone/cat...questid=422797
Car: 1992 Camaro RS
Engine: 8.0:1 454/Mild Hyd roller/Accel DFI
Transmission: WC T5
Axle/Gears: Stock 1992 open 7.5" 2.73 ratio
Yup. Get under the car, put your hand on the oil filter and move it up and you should feel it. It sticks sideways out of the block just above the filter. Doesn't get any simpler than that.
Axle/Gears: G92
Wow I read the first response wrong lol I feel stupid I know where the oil filter is. Thanks guys.
Hotrodboba400
Dec 10, 2019 07:07 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
