injectors
Old Jun 24, 2010 | 09:16 AM
Lasalt's Avatar
Car: 1991 Pontiac GTA
Engine: 5.7 350
Transmission: Automatic
injectors
I just started the restoration on a 91 GTA and im having a miss problem. The comprassion is amazing the plugs wires cap and rotar are brand new. Ive heard that the injectors go bad a lot in the 3rd gen birds so i was wondering what yall thought?? I have a shop out in Austin Texas so any kind of work is easy for me.
Old Jun 24, 2010 | 05:59 PM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Re: injectors
Not unheard of, especially with the stock Multecs that came in our cars. Go through and unplug each injector - figure out which cylinder it is, then check some of the other possibilities (maybe plug wire keeps melting on the manifold). Ohm out your injectors, see if they're all within the same values. If you decide to swap injectors, go for a set of Bosch style IIIs. There is a site (on of our sponsors I believe) that makes a set of Bosch IIIs perfectly fit for our vehicles.
Old Jun 25, 2010 | 09:17 AM
Lasalt's Avatar
Engine: 5.7 350
Re: injectors
3 4 5 6 those are the ones with no fire
Old Jun 25, 2010 | 03:55 PM
ntomsheck's Avatar
Car: 1989 GTA
Re: injectors
Haha that's more than a miss! Well, take a multimeter and test the resistance of each injector. If it's a stock set-up (most likely) then all injectors should test out to around 16 or 17ohms. If they are not all between 15 and 18 ohms, or some have vast differences, then you'll know for sure the injector driver coils are shorted out. Please note - even if the driver coils all test out okay, that doesn't mean the injectors can't be bad; they can still be plugged, or broken internally.
Old Jun 25, 2010 | 06:58 PM
Lasalt's Avatar
Engine: 5.7 350
Re: injectors
they all work and test out fine they just wont spit fuel... if there clogged i dont know what to do to clean them.
Old Jun 25, 2010 | 08:01 PM
southbay08's Avatar
Re: injectors
you can send them to us.... we will be more than happy to flow them for you! I agree with douchermann, no sales pitch intended, but if you do have the multecs, do yourself a favor and change them out for a set of bosch lll's. We have been running a sale for the past few weeks which ends June 30th. Just go to our site and type in code TG11 at checkout and receive 10% off. If you have any questions please do not hesitate to contact us!
KCG
Jun 24, 2020 04:33 AM
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
webeeZ28
Sep 14, 2015 12:00 PM
