fuel line size and fittings
Old Jun 25, 2010 | 11:40 PM
alexsholly's Avatar
Car: 91 rs
Engine: 305 tbi
ok fuel line is bent so i might as well replace it and the threads on the fittings are cross threaded(brother tryin to be helpful) so i need to know what size fuel line i will need to get i was thinkin of going with braided ss and what fuel sittings and also if local parts store wuld carry them. the line goes from the back of the trottle body closer to the driver side thnx for the help
Old Jun 25, 2010 | 11:47 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: fuel line size and fittings
This lists the sizes on the frame rail connectors (14mm x 1.5 thread return line, 16mm x 1.5 thread feed line) - can't help on the TBI side.
https://www.thirdgen.org/forums/memb...y-start-3.html
Unless you have a local speed shop, these fittings are not usually carried by the corner parts store.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
R3500
Aug 17, 2015 12:16 PM
