Coolant Temp Sensor
Old Jun 26, 2010 | 02:41 PM
IROCZdude's Avatar
Car: 88' Z
Engine: 350 .60 over
Transmission: W/C T5
Coolant Temp Sensor
ive been having trouble for a couple months now with starting issues ill start it, cranks fine but it will immediately die and i have to keep restarting it. i ran a scanner on it and its pulling the coolant temp switch code.
so im guessing its unplugged and its saying my engines at like -20 and its making it run lean
now the problem is i cant find the sensor i was told that it had a 3 pronged connector that plugged into it. in the hanes repair manual it only shows it on tpi and carb models i have the 305 tbi.
if someone could help me out that be greatly appreciated, im so frustrated with it.
Old Jun 27, 2010 | 05:56 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Coolant Temp Sensor
It is a 2 wire unit that is into the coolant somewhere
Either in intake like on TPI shown below ( most likely ) ,or into the heads.TBI uses same type sensor
Old Jun 27, 2010 | 08:30 AM
RyanEricW's Avatar
A socket directly over those things, I think 19mm right? Breaks the plastic top off it...
My CTS was on my intake next to my thermostat housing. I have a carb setup though.
Old Jun 27, 2010 | 09:01 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
On a TBI, the CTS, the temp sensor for the computer is right in front of the thermostat housing on the front of the intake. It has a plug with yellow and black wires going to it and looks just like the one vetteoz circled in his pic above.
Old Jun 28, 2010 | 02:50 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Need a deep socket
Old Jun 28, 2010 | 04:15 AM
RyanEricW's Avatar
Originally Posted by vetteoz
Need a deep socket
It was...
Bubbajones_ya
Jul 6, 2024 08:32 PM
92firebirdguy
Sep 1, 2016 07:53 AM
L98GTA87
Oct 19, 2015 10:43 PM
corey8084
Sep 17, 2015 02:56 PM
m00n420
Sep 11, 2015 02:39 PM
