leaking coolent
Old Jun 27, 2010 | 02:07 PM
spaigo's Avatar
leaking coolent
I have an 87 iroc 305 carb engine and below the distribtor cap and off to the side a little bit there is a little rubber casket or stopper and it is torn a little bit and radator fluid is squirting out of it
Can someone please tell me what this is and cheapest and easyest way to fix.
Old Jun 27, 2010 | 03:14 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: leaking coolent
Can you get us a pic?
Old Jun 27, 2010 | 04:07 PM
spaigo's Avatar
Re: leaking coolent
sorry could not get my camara in well enough to get a good pic but hopfully u can tell by the location, it is just a tiny rubber peice that sticks out
Attached Thumbnails leaking coolent-2010-06-27-16.45.42.jpg   leaking coolent-2010-06-27-16.46.06.jpg
Old Jun 27, 2010 | 04:15 PM
Twin_Turbo's Avatar
Re: leaking coolent
What rubber piece? Looks like it's leaking from a NPT port on the rear water passage. Is there some kind of sensor or thermal switch in there? Hard to see.
Old Jun 27, 2010 | 04:19 PM
spaigo's Avatar
Re: leaking coolent
maybe this will be easyer if you cant tell were pics are at
Old Jun 27, 2010 | 04:24 PM
spaigo's Avatar
Re: leaking coolent
there is a little rub peice that sticks up like maybe and inch and less then half inch in diamater between those 2 bolts
Old Jun 27, 2010 | 04:27 PM
Twin_Turbo's Avatar
Re: leaking coolent
Probably a npt to hose fitting w/ a cap over it? There is no gasket there, the 2 bolts are situated around the rear coolant port.
Old Jun 27, 2010 | 04:30 PM
spaigo's Avatar
Re: leaking coolent
how would i go about getting a new one and replaceing it
Old Jun 27, 2010 | 04:33 PM
Twin_Turbo's Avatar
Re: leaking coolent
If it's a npt to hose adapter, it screws out. If it's a switch or sensor that broke off, it too screws out.
Old Jun 27, 2010 | 05:16 PM
spaigo's Avatar
Re: leaking coolent
looks like it was annpt to hose adapter that was overed. on my next day off i will have to run to the store and pic up a cover.
Thanks alot man
Old Jun 27, 2010 | 05:21 PM
spaigo's Avatar
Re: leaking coolent
look at the tear down the side lol
Old Jun 27, 2010 | 05:27 PM
Car: 1992 RS
Engine: Carbed 350
Re: leaking coolent
I'm just trying to figure out what the heck is/was there. Never seen a coolant anything on top of th rear of the intake. Should be a manifold vacuum tree back there, and there is a hole on top of the china wall that is usually either plugged or has an oil pressure sending unit attached.
Old Jun 27, 2010 | 05:29 PM
Twin_Turbo's Avatar
Re: leaking coolent
On some cars the heater is connected to that port. Plugging it off w/ a rubber cap like that is asking for trouble. Get an NPT plug
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
