Problem:Rough idle / High RPM / Raw Fuel
Old Jun 28, 2010 | 11:47 PM
Downshift's Avatar
Car: 91 Camaro Z28
Engine: 5.0L LB9 305 TPI
Transmission: 5 spd
Axle/Gears: 3.42 Rear End
Hello every one, I need some help or advise figuring something out. I have a 91 Z28 (TPI) LB9 305 5 Speed. The problem started out of nowhere. I last drove the car about 15 days ago and everything was fine. Two days ago I went to start the car and it turned on but it started to surge with a low idle and I felt a strong smell of fuel in the exhaust as well as a lot of black smoke, the tach would go from 0 rpm, shoot up to red line and then come back 0 but the idle still seemed really low. It does this over and over a couple of times and then it dies out. There is no check engine light on and the car shakes roughly while it idles. The thing I noticed last time I drove it; I was on the freeway going up a steap hill, and the car started to shake really bad I did not know if it was the road ( L.A Freeways) whick looked pretty bad or if the car was detonating. I could not make out any pinging over the loud exhaust. I was going @ 50 in 3rd gear. Thanks for reading my short book, I would appreciate any input on this before I go out looking for a repair shop. Thanks again.
P.S I have:
adjustable fuel pressure regulator
MSD 6AL Ignition
Old Aug 21, 2010 | 01:58 AM
dmdonjuan's Avatar
Car: 500,000 mi. 89 Iroc,t-tops.
Engine: 383 stroker,chipped,msd ign, tpi.
Transmission: 700r4 rebuilt
Axle/Gears: LS1 front brakes, 2002 ls1 rear 342
Re: Problem:Rough idle / High RPM / Raw Fuel
mine just did about the same thing. it turned out it was my m.a.f.. try unpluging sensors one at a time and see if it runs better, assuming u have already checked the basics, plugs, wires, vacuum leaks etc.. be carefull unpluging sensors, watch your wires.. i spent two days troubleshooting my tpi, didnt think it was m.a.f. no check engine light.. replaced it 2 times past 10 years and always had a light.. keep us posted....
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
onebadazzsrt
Aug 15, 2015 07:00 AM
killer777
Aug 8, 2015 02:47 PM
