what does knocking sound like?
Car: 1987 BMW 325is
Engine: M20B25
Transmission: Getrag 260
Axle/Gears: 3.73 LSD
i ws putting in gas for the first time. the guyi bought it from said he always used 93 octane, but since the car has a stock 350 spec cam and "high output" 305 heads, i figure it doesnt need it. i put 89 in and as i was filling it, the car started making a loud, sputtering backfiring type noise for a few seconds. would this be knocking, or just bad gas or something similar? i mean now that i think about it i guess the 305 heads could have higher compression depending on what they are, but still...
damn- i just realized i posted the same question twice, trying to figure out how to close this, sorry
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: what does knocking sound like?
the 305 58ish cc heads will make more compression...
detonation ping sound.. ( is like a very small hammer rapidly tapping metal. lite case.. not very loud.. or a ring sound )
your combo needs to be tuned better.. to much timing?? AFR to lean??
I can put 87 Octane in my combo without pinging. I'm in the 11:1 range
PS your 2.72 gotta go.. you need to be in the 3 series range
Transmission: 4L80E/4L80E
Car: 1987 BMW 325is
Engine: M20B25
Engine: 231 / 383
Thank you,, you forgot to mention thats was a STI
there will be no need to tune.. deleting the air smog. due to it's not affecting your engine
yes.. I have cranked almost every setting to get my combo to run like it does
the headers are just EDL 6872
the ECU is fine.. I like to de-solder the eprom.. solder in a ZIF socket and flash my 27c256 EEproms.. you could get the ROMulator
http://secure.transtronics.com/osc/p...roducts_id/328
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
