400 heads???
Old Jul 3, 2010 | 03:07 PM
timespy's Avatar
Car: 91 RS Convertible
Engine: Soon to be swapped
Transmission: Memphis performance 700r4
Axle/Gears: Soon to be changed
400 heads???
I have a chance to grab up a very fresh set of pro built, ported and polished 400 heads. Will these fit onto my 350, and or what will I have to do to make them work properly. I am currently finishing up my new motor, and am using the crappy 624 heads. From what I have been told, almost anything would be an improvement over them. I thought I read something about steam ports needing to be plugged????? I only have a day or so to make a decision so any replies would be greatly appreciated. I dont know the casting numbers, but they were on a circle track car my cousin wrecked the first time out.
Old Jul 3, 2010 | 04:29 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 400 heads???
Yes, you can use them. No need to worry about the steam holes, just pretend they aren't there. If the chambers were enlarged around the intake valves, for de-shrouding, to match a 400 head gasket, then you'll also need to use 400 gaskets, but again, this isn't a problem.
Old Jul 3, 2010 | 04:51 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Re: 400 heads???
400 heads? why waste your time on some (most likely) crappy casting regardless of how "pro built" they area?
Old Jul 3, 2010 | 08:08 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 400 heads???
Stop bashing poor enthusiasts! Probably 10% better flow, ( if the porting was decent) for the price of a few gaskets. Plus 624s ALWAYS crack. Sooner or later, they ALWAYS do.
C409
Sep 23, 2015 04:30 PM
camaro71633
Sep 1, 2015 10:24 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
lakeffect2
Aug 23, 2015 08:44 AM
