HELP!!!
Old Jul 6, 2010 | 08:44 PM
shep236's Avatar
Car: '91 formula 5 speed
Engine: 5 oh
Transmission: manual T5
Axle/Gears: 3:43
HELP!!!
hey everyone, got my good ol trusty 91 formula firebird 305 tuneport. it wont start on its own, in other words i have to spray gas in the throttle itl start then stall when the gas fumes run out. i know my problem is my injectors wont pulse the fuel in. my fuel pump is good, my filter is new. i dont think the injectors are getting the electronic signal. it ran fine yesterday i installed an new coolant temps sensor an started it up, shut it down went to go start it an i just cranks. as i said i did a little diag so far but i need help on what could cause the injectors not to work. my VATS is in working order so its not that im just a little clueless and very frustrated
Old Jul 6, 2010 | 10:16 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: HELP!!!
do you hear the pump priming before you try to start?
