87 iroc engine troubles.
Old Jul 6, 2010 | 09:39 PM
lionsfb57's Avatar
Car: 87 iroc z
My 87 iroc started smoking today, so when i pull over and pop the hood, i find a lot of smoke and a broken belt -_- im not sure what this was to because the car ran perfect even without it. i cant take a picture of the engine or anything but if your standing in front of the car it is down on the front left of the engine. not 100% sure what this part is?
another thing, i had it out the other day and when i came home i heard a "gurgling" noise. so i pop the hood and see my engine coolant is bubbling and when i unscrewd the cap steam came out. my temps werent high on the gauges or anything. then when i came home after the belt braking today i noticed a puddle of anifreeze in my drive way.
Keep in mind it was 90 + both days...
Any help wiil be appreciated.
Old Jul 6, 2010 | 10:12 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 87 iroc engine troubles.
Belt sounds like smog pump - I'll bet the pump is bad, bearings froze up, thus the belt slipped on the non-moving pulley until it melted and broke. The added strain of the engine trying to run a belt against a dead pulley may have caused the overheating issue.
Old Jul 7, 2010 | 07:47 AM
lionsfb57's Avatar
Car: 87 iroc z
ya thats what i was thinking but i wasnt sure. Any idea where i could get one of those? and are they that important or do i just need one to pass emmisions? (PA inspectio)
Old Jul 7, 2010 | 11:47 AM
Car: 1992 RS
Engine: Carbed 350
Have you checked it? Take the belt off and see if the smog pump spins - you should be able to turn it by hand freely (unless it's froze).
Any autoparts store will have it - autozone carries them $79.99 ($10 core)
Old Jul 7, 2010 | 02:38 PM
lionsfb57's Avatar
Car: 87 iroc z
ya it froze up. When i first tried to spin it it wouldnt move, but after a while i broke it loose and i could spin it.
Frozer!!!
Jan 19, 2024 04:55 PM
italiano67
Dec 11, 2016 09:21 AM
kyleb24
Aug 15, 2015 08:24 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mustangman65_79
Aug 11, 2015 03:17 PM
