Does replacing the the oil pump decrease car value?
Old Jul 6, 2010 | 10:51 PM
Phoenixfire1989's Avatar
Car: 1989 Formula -1986 T/A
Engine: 305 V8 FI- HO350 V8 carb
Transmission: 5 speed manual- Automatic
Axle/Gears: stock - unsure
I know the oil pump is part of the engine..and i think it went bad on my car. My oil pressure has been reading 0. At throttle..its JUST above the red zone..and around 2000rpms or higher there's a clanking, even while parked. If this part is replaced, does it kill my restoration plans as far as everything being original?
Old Jul 6, 2010 | 11:30 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Does replacing the the oil pump decrease car value?
Internal engine parts don't count.
In a true resto ; only the block numbers have to be matching
Old Jul 6, 2010 | 11:33 PM
radical82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
Huh??? Come on man, you can't tell a joke witout giving us the punch line!!!! How much is "all original" worth when it kicks the rods out the side of the block????
Old Jul 7, 2010 | 12:20 AM
Thankx! i was kinda scared i would have to scrap the car. Trying to get it almost factory..see what it ran like back in its day
Old Jul 7, 2010 | 11:23 AM
Re: Does replacing the oil pump decrease car value?
Mechanic said the engine is on borrowed time. When we tightened up the top with the manifold gasket, everything else at the bottom that had worn a certain way over the years is making the engine knock. He doesn't think the engine is salvage-able.
Old Jul 7, 2010 | 12:16 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
The situation is not that bad. Engines wear out. You should have the engine rebuilt before it throws a rod by a competent machine shop so you can keep your numbers matching setup.
Old Jul 7, 2010 | 12:45 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
If it isn't blown, it is rebuildable. Pull it before you chuck a rod and destroy the block.
Reborn756
Sep 4, 2015 03:42 AM
NBrehm
Aug 25, 2015 11:49 PM
midias
Aug 22, 2015 01:42 AM
justin57
Aug 20, 2015 07:05 PM
MY87LT
Aug 17, 2015 08:43 AM
