what oil to use in my 383 stroker?
Old Jul 8, 2010 | 05:28 PM
jbradhill's Avatar
Car: 1986 Camaro IROC Z28
Engine: 383 SBC
Axle/Gears: 3.75 LS
I have a 383 stroker motor that I consistly run WOT up to ~6k RPM.
Motor specs
2.02 1.6 valves
Roller tipped rockers
Double valve springs
ARP headbolts
H-beam rods
SCAT crank
.250 domed pistons, 11:1 compression
Heads ported, gasket matched, etc. The intake is also gasket matched.
Holly 780 Carb, Edelbrock Performer RPM Manifold, electric Fuel Pump
... now my question. What motor oil should I be using?
Old Jul 8, 2010 | 05:45 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What type of lifters, roller or flat tappet?
Old Jul 8, 2010 | 06:16 PM
jbradhill's Avatar
Engine: 383 SBC
Axle/Gears: 3.75 LS
Re: what oil to use in my 383 stroker?
... wish I knew. I didn't build it, so I am not sure how to figure that out.
Old Jul 8, 2010 | 06:36 PM
five7kid's Avatar
What do you know about it? Rear main seal type? Block casting number? That may give a hint, but the only real way to know is to look at the lifters. If you trust the person that built it, you could ask.
A "safe" oil to use would be a 5W-30 or 10W-30 that is rated for both diesel and gasoline engines. The diesel rating needs to be API CI-4+ and gasoline rating API SL. These oils will have the ZDDP anti-wear additive needed to protect flat tappet lifters. This is what I used in my flat tappet engines http://www.amsoil.com/storefront/hdd.aspx .
What you want to avoid are oils with API CJ-4 or SM ratings, or ILSAC GF-4. These oils have reduced ZDDP for emissions equipment protection purposes. Older engines like ours don't have that issue, but flat tappet lifters need that ZDDP. If your engine happens to have roller lifters, the CI-4+/SL oil will still be fine.
Old Jul 8, 2010 | 08:10 PM
jbradhill's Avatar
Engine: 383 SBC
Axle/Gears: 3.75 LS
Thx! So it looks like it is the Zinc that is needed
buckshot63
Sep 10, 2015 09:15 AM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
IROCZ1989
Sep 4, 2015 11:54 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
