Starting Problem 91 Z28
Old Jul 8, 2010 | 06:31 PM
CamaroGuy101's Avatar
Car: 1991 Z28
Transmission: 700 r4
My problem is this, whenever i turn the key, sometimes it starts up like normal, but sometimes it does nothing, however when it does nothing, pumping the clutch a couple times cranks it right up.
The info:
Its a 1991 305 Tpi manual
This isnt a serious problem, just something id like to fix.
Any help is appreciated!
Hope you guys can point me in the right direction.
Old Jul 8, 2010 | 07:31 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Starting Problem 91 Z28
if pushing the clutch seems to correct the issue, the problem may be with the neutral safety switch/wiring on the clutch pedal bracket.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
