starting my build is this a good setup?
Old Jul 9, 2010 | 07:46 PM
rx8camaro's Avatar
I have a 1992 camaro z28 350. I want to run AFR heads with hotcam. TPIS lower intake and runners. I have a edelbrock throttle body, hooker 2460 headers, already which i would like to keep. what do you think will all this work together or what should i change. i am not going to monster power or anything. i might be intested in superchargering someday. thanks for any input before i start laying down money for all this.
Old Jul 10, 2010 | 01:03 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Re: starting my build is this a good setup?
I wouldn't waste my cash on the AFR heads if you are just planning a mild build using a relatively small cam. You'll kind of be paying for performance that you won't be using (at least any time soon)
Old Jul 10, 2010 | 08:39 PM
rx8camaro's Avatar
what is a good set of heads then to run with the hotcam?
Old Jul 11, 2010 | 03:33 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
If you can afford the AFR heads, get the 180 cc version, with 65cc chambers. They're the very best heads for SBCs, especially when using a power adder ( nitrous / boost).
There's no disadvantage to them except the initial cost. The HOT cam isn't the best choice, it gives away too much low-rpm torque, down below about 2500 rpm. But if you're running a 2500-stall converter and 3.42:1 gears, then go for it.
specialized
Jun 18, 2022 09:26 AM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
justin57
Aug 20, 2015 07:05 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
