I know its not a camaro
Old Jul 14, 2010 | 02:40 AM
TazCowboy's Avatar
Car: 1991 Camaro RS
Engine: 350 SBC
my camaro doesnt have a/c however I have a 94 suburban that does and the clutch doesnt engage and I know it works cause I tested it with direct power any suggestions. we are expecting twins next month and would sure help out. I did replace clutch cycling switch with new one and 1 from u pull it
Old Jul 14, 2010 | 06:40 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: I know its not a camaro
You could rig up a manual switch, or you could go get wiring diagrams and a DMM and chase it down.
Old Jul 14, 2010 | 08:46 AM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Yeah be careful with the manual switch. The compressor is supposed to cycle, not run 100% of the time. These things aren't built for 100% duty cycles. The AC system will still cool with just a little bit of refridgerant, but the pressure switch might not be happy with the amount of refridgerant in there. Could also be a faulty pressure switch.
Old Jul 14, 2010 | 09:56 AM
TazCowboy's Avatar
Car: 1991 Camaro RS
Engine: 350 SBC
I have a gage that came with the R134a and it reads charged when clutch isnt engaged but not charged when manually engage clutch. which is right?
Old Jul 14, 2010 | 01:53 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Not charged.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
