375hp 305 build
Old Jul 15, 2010 | 09:07 PM
doop327's Avatar
Car: 86 iroc-z
Engine: 355 vortec heads, 750dp, xe268
Transmission: 700r4 kitted
Axle/Gears: 3.23 posi 10 bolt
375hp 305 build
i just bought 2 yes 2 sets of vortec heads for 200 bucks, and a new holley 650 double pumper for 100, and my new engine kit from summit is on the way!!! anyways im about to do the "hate me" 305 build up but next step bigger cam. Just thought i would brag a lil bit.
Old Jul 15, 2010 | 09:11 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: 375hp 305 build
And how are you getting 375 horse out of that motor?
Old Jul 15, 2010 | 09:20 PM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
Re: 375hp 305 build
Your not far from me, but I HIGHLY doubt your going to get 375 hp out of that motor with just heads and a hot cam.
Old Jul 15, 2010 | 09:21 PM
doop327's Avatar
Car: 86 iroc-z
Re: 375hp 305 build
milled .030 vortec heads, flat top pistons, edelbrock air gap, holley 650 double pumper and comp cams xtreme energy 274 cam, pulleys, ignition etc etc. behind my t5 it should be a fun ride.
Old Jul 15, 2010 | 09:25 PM
doop327's Avatar
Car: 86 iroc-z
Re: 375hp 305 build
google HATE ME 305 build or 375 horse 305 and it the atricle will pop up, plus im going a step bigger on cam
Old Jul 15, 2010 | 09:51 PM
FlippindaBird's Avatar
Car: 1987 Firebird, Dad bought it new
Engine: 5.7L Vortec w/ LT4 Hot cam
Transmission: 700r4 transgo shiftkit 2600 stall
Axle/Gears: 3.42 '02 SS 6 spd rear
Re: 375hp 305 build
What do those heads cc at after milled 30?
Bigger cam- more hp?!? Maybe, maybe not
More hp- faster car?!? Maybe, maybe not
Good luck though I'm definitely rooting for you. You gonna dyno it when your done?
Edit just read the article. Use a 87+ 305 and a roller cam. It'll also have a little better cr prolly around 9:1 if that was computer friendly prolly make 325 plus which would be pretty dam respectable from something that would look stock and pass inspection to boot(in an LG4 car) with hooker 2055Rs
Old Jul 16, 2010 | 02:17 AM
doop327's Avatar
Car: 86 iroc-z
Re: 375hp 305 build
im gonna have flat tops=more compression step up over 268 cam xe 274 and compression should be between 9.5-10. heads will be 60 cc after a .030 mill on the vortecs.
Old Jul 16, 2010 | 03:02 AM
Doom86's Avatar
Car: '86 Z28, '91 RS
Engine: 305ci, 305ci
Transmission: TH200c (no kidding), TH700r4
Axle/Gears: 2.73, 2.73
Re: 375hp 305 build
What headers and exhaust are you using?
Old Jul 16, 2010 | 07:10 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 375hp 305 build
Wrong. As much as the Vortec heads are advertised as 64cc, the fact is, they're closer to 61 cc. Lots of them do check in at 62cc. So with a 0.030" cut, you'll have more like 57 cc.
Ussing the SpeedPro H534CP60 pistons would be wise, but so would sticking them in an '87-up block, and using Lunati's 54743LUN cam. combine that with some porting in the Vortec exhaust ports, as shown in this thread: https://www.thirdgen.org/forums/engi...c-heads-2.html then use these valves: http://www.competitionproducts.com/S...ductinfo/8430/ and you can expect just as much peak HP as what you've tyuped, but much more average power, and a lot more torque in the mid-range. Assuming the RPM AirGap and Hedman 1.625" long-tubes.
Old Jul 16, 2010 | 07:35 AM
Re: 375hp 305 build
Roller cam was the other reason I said to use the 87+ get that power to the ground, should be a chore with the t5 but a fun chore! Slicks would be my next investment after the engines done
Jake_92RS
Jan 28, 2020 10:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
formula_novice
Sep 5, 2015 03:58 AM
Reborn756
Sep 4, 2015 03:42 AM
makaveli09
Aug 12, 2015 09:07 PM
