Help Please
Car: 84 Z28
Help Please
hey guys, started the car today and noticed loud noise coming from passenger side valve cover, right by the firewall, oil level is fine, i took it for a short drive and its running alot hotter than usual, and when i come to a stop it wants to die and then revs up a bit to keep it running and repeats itself...
its a rebuilt 350 in my 84 Z28 with maybe 10,000km since rebuild, could this be carb related? not sure where to start but need to fix asap...
Car: 84 Z28
Re: Help Please
ok then... i pulled the valve cover to check if i can can see anything wrong but dont relly know what to look for, how much play should the valves have? is there a tork to them?
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: Help Please
Run the car with the valve cover off and see if a rocker arm or two arent moving as much as the others. The nut could have loosened up or a lifter or cam lobe is tore up.
Car: 1984 z28
Engine: 355
