I have a few questions
Car: 1984 Firebird S/E
Engine: 5.0L 305 V8
I have an 84 Firebird with a 305.
1. Sometimes when I turn off the car the engine keeps running. It sputters and eventually shuts off. What could cause this?
2. When I shift into drive my gas pedal becomes very stiff. If the car is in park the pedal works just fine.
3. The person who had the car before me installed a B&M shifter. You really need to pull hard on it to shift. Is this normal?
4. The car drives slowly until it reaches 2800-3000 RPM and then it finally shifts gear. I'm wondering if the previous owner installed a torque converter that could be causing this. If not then what else could it be?
I'm not mechanically inclined and I just got this car so I'm sure this wont be the end to my questions. Any help is appreciated.
Transmission: 4L80E/4L80E
Probably a misadjusted TV cable.
