1988 IROC Conv. Humming noise.
Old Jul 21, 2010 | 04:12 PM
gidyuppp's Avatar
Hello. New poster, however I have a Grand National as well and find that message board to be a great help so hopefully I can get an idea of what is going on with mine here.
I have a 1988 Iroc Conv. 5speed, 305 TBI. The car is 100 percent stock with 52K miles. It runs awesome and I have no troubles with the car at all. However, last week I drove the car for about 1 hour and pulled it in the garage and heard this humming noise coming from under the car near the rear end. The car was hot so I couldnt do much to see what was up and it stopped about 5 mins after I parked it. As a prevention step I services the differential fluid. I drove it a couple more times and no noise. Last night after a car show it was making the same noise again. Same humming in the same area. My best guess is the differential but I cant generalize the noise because of the hot car. It is coming from behind the rear seat area up to the gas tank. Like I said earlier the car drive fantastic and I have no common problems associated with a rear end issue. The noise goes away quicker than I can identify it. Any ideas?
Old Jul 21, 2010 | 04:54 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: 1988 IROC Conv. Humming noise.
Just turn the key to "run", dont start it. The fuel pump will prime for about 3 seconds, does it sound the same as the noise your hearing? Maybe the pump isnt turning off when it is supposed to.
Old Jul 21, 2010 | 06:48 PM
gidyuppp's Avatar
Thanks for the suggestion. The noise I hear is much, much louder than the fuel pump. I tried your suggestion just to pay more attention and that 3 second or so noise is very faint. I then drove it about 20 miles and came home and no sound at all. You dont hear it at lights when top is down, only after car is turned totally off. Even when I hear the noise when car is off I will start it up then go down to listen and it goes away. Quite funny and I never heard anything like this. I owned a 1983 Z28 TBI many years ago and owned that for 12 years and never heard that. Thanks for the help
Old Jul 23, 2010 | 03:34 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Power antenna perhaps? If the mast becomes stuck or the mast cable breaks, the motor will run on. The relay is under the right side dash and can be unplugged to turn off the motor.
Old Jul 24, 2010 | 08:29 PM
gidyuppp's Avatar
Thanks ASE. Noise is clearly between the rear seats and fuel tank. Radio is powered off and it still makes the noise on occasions. Had a suggestion that it is the fuel pump and that having a full tank more than not may stop the pump from working harder??? Worth a try. Since I only hear the noice at certain times, I really have not checked my gas levels when hearing it. I know the other day I was under a 1/4 tank. So I filled up. Its the strangest thing. Thanks everyone
Old Jul 24, 2010 | 08:57 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Thats a very good point. I was under the impression that the noise was being heard with the ignition off. In tank pumps can get noisy when they are close to failure. If you determine that to be the cause of the noise, you should consider replacing the pump. No guarantee how long it will last once it starts making noise.
Old Jun 27, 2012 | 06:13 PM
Michelle Mahr's Avatar
Pressure in the gas tank. Evap canister is building pressure. Unscrew the gas cap.
Old Jun 28, 2012 | 11:36 PM
Caniac's Avatar
i can promise you that it is your fuel pump. i had the same problem.
the noise keeps getting louder and louder. the longer you drive. sometimes it even shutdown on me. but ya by the time you hear the fuel pump while driving, its a lot louder than it sounds when it primes at the beggining
bought the car changed the fuel pump.
new fuel pump was a faulty fuel pump.
changed it again and car runs perfect.
i dont hear that humming at all anymore.
Old Jun 29, 2012 | 06:18 AM
NY87Iroc's Avatar
Car: 1987 Iroc convertible
Axle/Gears: 3.42 posi
This is what I was going to say..Unscrew the gas cap and see what happenes.
theshackle
Sep 17, 2020 08:26 AM
stalkier
Aug 21, 2015 01:54 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
