clutch not fully disengaging?
Old Jun 28, 2012 | 11:47 PM
Caniac's Avatar
my bad if this is in the wrong section.
work I've had done to clutch:
new master
new slave
new clutch
flywheel resurfaced
Problem:
had the master cylinder replaced 2 days ago. new master cylinder when pushed does not go as far down (towards the floorboard) as my old one. it goes down far enough to when i hold it and I'm in gear that the clutch does not engage, but as soon as i let off the clutch a little it starts engaging. however, when I am in neutral at a complete stop trying to go into first it gives me trouble; sometimes i have to press the clutch in really quick and throw it in gear.
so please if you have any ideas, I am open to hear them.
Edit: Forgot to say i cannot simply put it in reverse. ive tried going from 1st to reverse going through the gears to reverse everytime i put the car into reverse it grinds so i have to throw it in reverse fast
Old Jun 29, 2012 | 05:25 AM
KrazyFirst's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: WC t5
Axle/Gears: Stock
Re: clutch not fully disengaging?
Clutch line to the slave sounds likes its failing. Also bleed the system again. See if you have any air in the system. Good luck!
Old Jun 29, 2012 | 07:20 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
How much material did they take off of the flywheel?
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
Night rider327
Sep 2, 2015 04:18 AM
