SES - code 36, then no codes?
Old Jun 28, 2012 | 11:41 PM
mav75's Avatar
Car: '89 Trans Am
Transmission: 700 R4
OK, the first mistake I made was let a local oil change shop talk me into running a fuel injector cleaner through my rails because of what they claimed were carbon deposits on the intake valves.
Two days after I let them do it, I got an SES light and pulled a code 36 by grounding the A & B terminals of the ALDL with a paper clip. I checked connections for the MAF sensor and burn off circuit relays, and they looked good. The shop said sometimes SES lights come on with that code if the connection to the MAF sensor has been disrupted and clearing the code should resolve it.
I did that, and then took the car out for some mixed driving. After about 20 minutes of driving, I shut the engine down to let it run through its burn off cycle. Then I started it up again, and the light went away. I repeated that three times with the same results.
I thought I was done, but tonight the SES light came on. This time, all I'm getting is 12's.
Did I fry the ECM?
Old Jun 29, 2012 | 08:57 AM
mav75's Avatar
Car: '89 Trans Am
Re: SES - code 36, then no codes?
Never mind...the SES light always stays on when the engine's not running. I'm one of those people that when armed with a service manual, I know just enough to be dangerous...but I'm trying to learn!
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
