305 tbi ticking rod bent.
got headers put on and shop said i was running wrong spark plaugs(stupid mistake i know) but one of the rods is bent so u can hear it ticking its loud. i need to know whta vavles rod to get and pistonheads wuld be best wuld like a lil more performance. and also about how much would it cost to have them put on my car
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: 305 tbi ticking rod bent.
i for one am confused . are you asking about a piston rod or a valve pushrod ? also not sure what you mean by pistonheads ??? if you have a bent piston rod you need a major overhaul . if it's a bent valve pushrod , easy fix . cause may not be an easy fix . more/better info. needed . good luck . Last edited by UNCLE TOM; Jul 22, 2010 at 07:35 PM.
