Set timing with vacuum gauge
Old Jul 22, 2010 | 08:02 PM
usmc949803's Avatar
Car: 92 Camaro RS
Engine: 77' 350 bored 355 Holley carb
Transmission: Turbo 350
wanting to set timing on 77 350 w/carb with vaccum gauge. read and heard a few different things and ways..... ideas... thanks
ps timing tab is gone anyways
Old Jul 22, 2010 | 08:20 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: Set timing with vacuum gauge
you can set your timing with the vacuum method..
your car should be making around 9 - 14 PSI.. with a moderate cam
disconnect you advance.. and set your timing with the most vacuum without pinging
your still guesstimating.. I would leave the gauge on turn toward the windshield and do part a full throttle runs
you can always purchase a bolt on TAB
Old Jul 23, 2010 | 04:32 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Yay to the bolt on tab. Be sure to check your balancer though. Some carlines and most trucks had the timing tab at 12 o'clock. If you have a balancer for one of these applications, the timing mark wont line up with a bolt on tab. The vacuum method will work, mostly following the ping part of the method. Advance til you hear pinging then back off two degrees. The vacuum reading will vary greatly depending on your cam, fuel mixture, exhaust back pressure, engine mechanical condition. Thats why we set timing with a light.
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
86IROC112
Aug 17, 2015 02:00 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
