91 gta starting/fuel prob
Old Jul 25, 2010 | 02:11 PM
jstricker5133's Avatar
Car: 1991 GTA
Engine: 5.0 tpi will be 5.7 tpi
I have a 91 gta, the fuel pump dont purge, but starts if you use starting fluid, then will run fine, will even restart without starting fluid, unless it sits for awhile. Tried swaping fuel pump relays. Starting to think it may have something to do with chip in key, aftermarket alarm/remote start. please help
Old Jul 25, 2010 | 07:23 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 91 gta starting/fuel prob
If the chip in the key was not working, the injectors would not fire at all, and the starter would not run at all, so it's not the chip (VATS). Are you sure you swapped the fuel pump relay and not a fan relay?
Old Jul 28, 2010 | 07:09 AM
Car: 1991 GTA
im pretty sure the fan and fuel pump relays are next to each other on the driver side firewall and exactly the same i switched them still had same problem
F-body-fan
Jan 12, 2023 01:49 PM
sheachopper
Jul 31, 2019 11:27 AM
sparks454
Interior Parts Wanted
Oct 18, 2015 03:18 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
