aftermarket fuel regulator--TPI
Old Jul 26, 2010 | 06:58 AM
matt1970pon's Avatar
Car: 1987 iroc z
Engine: 305 tpi
Transmission: MM5
Axle/Gears: 3.45 g92
I'm having a high PSI fuel issue. Its fine with pump on ignition off but as soon as i crank and run it hits 60.I checked return lines and all are clear. I installed a new diaphram and BBK ajustable cover on it.Doesn't help. Could I put an aftermarket regulator on the inner wheel well then "T" in the return line? I want to keep the factory regulator in since I don't know how to delete it.That should work since the factory regulator would just be getting the correct PSI,is that correct?
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
theurge
Aug 21, 2015 12:46 PM
92camaroJoe
Aug 13, 2015 06:07 AM
