Idle rpm help!
Old Jul 28, 2010 | 12:54 PM
xxpotandaxx's Avatar
Car: 1992 Camaro z28
Engine: 5.0 TPI
Transmission: 5 Speed Manual t5
Idle rpm help!
What rpm should my car be idleing at ? and how do i adjust it?
Old Jul 28, 2010 | 12:55 PM
Engine: 5.0 TPI
Re: Idle rpm help!
i forgot to say its a 305 tpi
Old Jul 28, 2010 | 01:49 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: Idle rpm help!
Idle is computer controlled. It should be at 650 with all accessories off. If it is not correct, you will need to perform idle air control reset procedure. Warm up engine, turn off ignition, disconnect IAC, restart engine, adjust idle to 450 by turning base idle screw(may need to remove plug covering screw), reconnect IAC. If engine will not idle at 450, figure out why.
Old Jul 28, 2010 | 01:59 PM
Engine: 5.0 TPI
Re: Idle rpm help!
Thanks !~! ima go do that now
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCtometal
Sep 2, 2015 02:01 PM
