where to buy...
Old Jul 30, 2010 | 06:56 PM
griemar's Avatar
Car: 86' Camaro
Engine: 2.8L V6
where to buy...
Does anyone know where I can buy a complete or near complete 2.8L MPFI? I'm looking for a spare/play/backup engine. I've called every junk yard in my area and nobody has them. I'd like to keep my budget around $500 ish but that's not firm and I prefer the engine be in running condition but doesnt have to be perfect since I'll be playing with it.
Old Jul 30, 2010 | 07:18 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: where to buy...
Where do you live? Around here, getting such a thing can be done for under $200.
Old Jul 30, 2010 | 07:26 PM
griemar's Avatar
Car: 86' Camaro
Engine: 2.8L V6
Re: where to buy...
Reading Pennsylvania. Finding anything 3rd gen around here is proving to be rather difficult.
Old Jul 30, 2010 | 09:12 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: where to buy...
The short-block assembly from a 2.8L S-10 will work. Avoid pre-'85 versions. The heads from a Fiero 2.8L will work, they're the same as the F-car heads. Also, 3.1L and 3.4L F-car heads are the same. The Fiero guys have totally scienced-out what it takes to use the '93-'95 F-car 3.4L in place of a weak 2.8L. Fiero blocks had the starter on the wrong side, as did the FWD cars. Aluminum head versions are plentiful in the FWD cars, but you can't use those. You also can't use their deep-dish pistons, or their roller rockers.
That should get you started.
Old Jul 31, 2010 | 02:08 PM
griemar's Avatar
Car: 86' Camaro
Engine: 2.8L V6
Re: where to buy...
Thanks for the heads up, I'll start looking for 85' and older S-10's with the 2.8. I've seen several of those around. I was originally going to do the 3.1 swap, but my lack of available tools and knowledge of engine swaps has steered me away from it until I can afford to have a shop do it. As for Fiero's, they are about as hard to find around here, if not harder to find as any F-bodies.
propaintball96
Sep 25, 2014 10:26 AM
propaintball96
Mar 11, 2014 04:46 PM
KiLLJ0Y
Southern California Area
64
Jun 3, 2010 01:42 AM
CD MaroMan 91
Car Audio
Jan 27, 2002 04:00 PM
KlayBuRn
Car Audio
Mar 20, 2001 01:13 PM
