Coolant Leak?
Old Aug 2, 2010 | 05:06 PM
BlueWrath92's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 10 Bolt 3.42 Posi
Coolant Leak?
alright past week I noticed the coolant lvl going down little by little, I do need a coolant flush seeing that there is rust in the overflow bottle, but I see no noticeable leaks, no smell of coolant... no coolant in oil, no oil in coolant... seems to be burning off or something, was thinking small leak in pump but cannot see visible leakage.... any ideas where to start?
about 32 oz in a week of coolant leakage
Old Aug 2, 2010 | 05:12 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Coolant Leak?
Water pump would leak from the bottom - there is a 'weep' hole there, when the pumps start to go out, coolant 'weeps' from that hole - might try letting it run while it's on ramps (get up to temp), and crawl under and look - be careful, you don't want it in your face.
Old Aug 2, 2010 | 05:17 PM
Car: 92 Camaro RS
Engine: 305 TBI
Re: Coolant Leak?
alright....but im small enough to get under with no ramps I dont see coolant in that hole but the pump pully does squeel fairly loud tho., im about to go under now but If I see nothing can u give me more steps?...I do see a buncha gunky buildup in the front of the intake manifold to but its old ****
Old Aug 2, 2010 | 06:43 PM
Car: 92 Camaro RS
Engine: 305 TBI
Re: Coolant Leak?
ok, I see no leaky pump from the top or bottom hole or gaskets, I do see a nice wet area in the back of the engine around the distributor area, any thoughts?
Old Aug 5, 2010 | 04:39 PM
dv013003's Avatar
Car: Firebird Formula 350
Engine: 5.7
Re: Coolant Leak?
I am not familiar with your engine, but if you have engine oil coolant lines running to a sandwhich plate above your oil filter, there is a hard line that carries coolant to the oil filter area. see if this line has rusted through and if there is a pinhole.
Also, you can see some other ideas on a post that I replied to that was posted yesterday or so (also named "coolant leak" I believe.
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
aaron7
Sep 30, 2015 09:15 AM
