how much to pay for vortec heads
Old Aug 3, 2010 | 01:26 AM
luke89's Avatar
Car: 96 jeep cherokee, 89 camaro
Engine: 355
Transmission: t5
Axle/Gears: eaton locker/3:73 gears
these are on craigslist and was wondering how much i should offer him. whats a good starting price and whats the most i should pay? and will these work good with a edelbrock performer rpm cam?
i got flat top pistons, how much compression should i expect?
THANKS!
Nicely done all new fresh set of small block chevy Vortec heads
screw in studs, guide plates, 600 lift springs, 1.94 valves
gasket matched, drilled for older intakes, #10239906
make offers, moving sale need gone ASAP, 262-880-8648
Old Aug 3, 2010 | 01:45 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: how much to pay for vortec heads
THANKS!
Since you can pick up a set for around $350.00 each for new Iron ones from Scoggin Dicky. The ones they have modded for .600 lift springs run $430.00 each. I hope that helps to give you a starting point since they also offer a limited warranty with them. The vortecs will not work with a Performer RPM intake, you will need to get the Edelbrock Vortec intake equivilent...I think it's called the E-tech or something like that. However, it should work with the cam just fine.
Old Aug 3, 2010 | 09:40 PM
luke89's Avatar
Engine: 355
Transmission: t5
im gettin them for 400. you thinks thats a fair price?
Old Aug 3, 2010 | 11:41 PM
Ozz1967's Avatar
Car: 1984 Trans Am
I think if you get both for $400, it's a steal. If it's $400 each, then it's equal price compared to new with the same work done.
Old Aug 4, 2010 | 12:47 AM
luke89's Avatar
Engine: 355
Transmission: t5
im gettin both for 400 so i guess i did pretty good.
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
