Smog
Old Aug 4, 2010 | 06:16 PM
transamman83's Avatar
Car: 83 Trans am, and 91 Camaro
Engine: both have a 305.. For now
Smog
I have a 83 trans am with a h code engine. I was wondering if it is ok to just take off all of the smog stuff. What troubles will i run into? any tips from someone who has already done this. Thank you very much.
Old Aug 20, 2010 | 10:10 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: Smog
Well, you can take the stuff off if you want, but it is against the law to do so. Had an 82 z28 that someone de-smogged and they had replaced the carb, intake, and distributor, so it really isn't worth it for the money the non smog stuff cost.
Old Aug 21, 2010 | 12:15 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Smog
Won't affect anything performance wise leaving it on or taking it off. There's a ton of threads about it - do a or check the tech article (just ignore the serp belt stuff since you have a vbelt setup) https://www.thirdgen.org/serpentine
jaridjohn
Oct 5, 2015 07:01 AM
wstephan96
Sep 25, 2015 04:28 PM
