Firing problems
Car: 1991 Camaro RS
Engine: Carb 350ci bored .40
Axle/Gears: 2.73:1
Firing problems
So ive been working on my 91 rs.
Just got a new PROM chip installed with my new ECM.
No more check engine light (Had code 51 - PROM error)
Went to fire up my camaro, and it makes all the sounds like its about to start up. But doesn't. What would keep it from starting up.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
It’s About Time
Have you checked timing?
Happy Racing!
He Must Have Been Be Cheating - Because I Was And He Almost Beat Me.
Happy Racing!
Car: 1991 Camaro RS
Axle/Gears: 2.73:1
Re: It’s About Time
No, but what im thinking is its VATS.
A carshop wired in my key inline with the VATS system.
Im thinking now with the new PROM that the resistance on the key isnt right.
So it wont fire up?
im thinking just pull the key out and connect the wires back together and see where that leads me.
But thats just off somethings that ive read on cars with similar conditions.
So it wont fire up?
Transmission: 765R4
Re: It’s About Time
The VATS disables the starter therefore you wouldn’t even hear cranking, much less the other sounds of it trying to start.
Happy Racing!
My Brakes Don’t Work AT ALL When The Car Is In The Air
Car: 1991 Camaro RS
Axle/Gears: 2.73:1
Re: It’s About Time
Oh, was an older post sorry.
Since this post I've reprogrammed my chip. well had it reprogrammed.
And upon installing it the second time
the car doesnt even crank. Power is going through the car, when key is turned nothing happens but battery draining. (I know this because I turned my fan on 1st to see what It would do, and it was soon cut off due to voltage lost)
Transmission: 765R4
Car Isn’t Cranky So I Am
Using a voltmeter or test light (the type for testing for voltage, not a continuity tester) probe the yellow wire at the starter enable relay, which is located under the left kick panel.
Is there power there when you try to start the car?
Happy Racing!
Does The White Flag Mean He’s Surrendering?
Happy Racing!
92camaroJoe
Aug 13, 2015 06:07 AM
