How not to keep your rocker arm nuts from getting loose
Old Sep 1, 2010 | 06:22 PM
kd5icr's Avatar
Car: 1985 Camaro Z28
Engine: 305 mild build up
Axle/Gears: Stock
I have seen many really stupid thing done to cars as has many of you. But I never recal seeing the rocker nuts welded to the studs berfore.
Here I was just starting to replace the valve seals to stop the smoking when out of the blue WHAM a kick in the ....well you know.
Here is a photo of what I ran right into. Who ever worked on this before I got it was a TOTAL IDIOT, this guy desided to weld all 16 of them to the studs. And by weld I mean to the point I have no other opition but to pull them off. I am sorry the photo is a little blurry, but you will get the point.
Oh well I was thinking of getting a new set of heads, I might as well do that now, no telling what other damage I will see.
Attached Thumbnails How not to keep your rocker arm nuts from getting loose-welded-rocker-nut.jpg
Old Sep 1, 2010 | 06:55 PM
RazorN8's Avatar
Car: 1987 camaro
Engine: 383 AFR heads
Axle/Gears: Ford 9" 3.70:1
Re: How not to keep your rocker arm nuts from getting loose
I don't know what your talking about, that's high performance
Old Sep 2, 2010 | 10:18 AM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Nonsense. Those are the special edition.
Old Sep 2, 2010 | 10:27 AM
kd5icr's Avatar
Axle/Gears: Stock
I think I got luck on this one. The nuts are coming off, And the camaro club I am in one of the other members just gave me a set of later model 350 heads. All I have to do is go get them, they are very low milage so as long as the center intake bolts arent canted I will use them, if not I have a core to use.
Hotrodboba400
Dec 10, 2019 07:07 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
New2Chevy
Sep 28, 2015 12:35 AM
ericjon262
Sep 11, 2015 06:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
