350/ho416 heads.. questions
Old Aug 17, 2010 | 10:02 PM
toolegit86's Avatar
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Axle/Gears: disk rear, 10bolt.
so i got my set up complete and running it has good power and is actally a strong motor, my questions are for the guy running this set up.. what plugs are u running, and what is ur timing set at..
the car has good power but sometimes it acts like it is blowing the spark out, the car raps out good till 45-5000 good sounds like its missing then snaps up to 6500 easy now it only does this every once in a while.
my timing is set at 12-14btdc i do have a advanced kit in the hei.
iam thinking its the valve springs/ needs a aftermarket coil and pick up. and i am running oe autolight plugs
Old Aug 17, 2010 | 11:59 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 350/ho416 heads.. questions
What module are you running?
Old Aug 18, 2010 | 10:17 AM
toolegit86's Avatar
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
stock, thinkin of gettig the accel or pertronix
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
