AAAAARRRR Fing start
Old Aug 15, 2010 | 11:21 AM
bad to be blown's Avatar
Car: 89 gta
Engine: 5.7 supercharged
hi guys
as you can prob tell getting a little fed up of my ta at the mo
got her about 5 mouths ago knowing she needed work and was going to be a summer project. main problems bad wiring and the floor is gone.
any how been working on her all the wiring is done now.
last week did a trans fluid/filter change.
flushed the rad out
took of the pulley for the supercharger as it was buckled sorted it and put back together
and now she just wont start
has spark, fuel and air but will not catch
she tyring but just not good enough
please any ideas guys would be great
o and she a 3rd gen 5.7 tpi
Old Aug 16, 2010 | 01:01 PM
Car: 89 gta
Re: AAAAARRRR Fing start
any one???? reallt need help here guys
Old Aug 16, 2010 | 01:17 PM
racethesunlive's Avatar
Car: '92 Camaro
how did you confirm spark and fuel? Are you sure the fuel injectors are firing?
Old Aug 16, 2010 | 01:18 PM
Doom86's Avatar
Car: '86 Z28, '91 RS
Engine: 305ci, 305ci
Transmission: TH200c (no kidding), TH700r4
Axle/Gears: 2.73, 2.73
Could it be the VAT system?
Have you checked the easy stuff like volts at battery and volts at starter solenoid?
Smarter people then me will need a little more info to help. The year, induction, ect. would help a lot.
Old Aug 16, 2010 | 01:28 PM
Car: 89 gta
more info
she a 89 gta 5.7 tpi with a vortex supercharger
tested the sparks with ignition bulbs
fuel with psi reader
Old Aug 16, 2010 | 01:29 PM
stealthroc89's Avatar
Car: 1989 IROC-Z
Engine: 355, 6.0 (LQ4) soon
Axle/Gears: Borg Warner 2.77 for now
Did it run before (in your posession)? I'd start by checking the timing and fuel pressure. Have you tried pulling codes from the computer? My bro had this problem with a supercharged 96 T/A, long story short, do a compression test. It'll save you alot of headaches
Old Aug 16, 2010 | 01:42 PM
Car: 89 gta
ya she ran when i got her its only since i did these jobs shes stopped working
just waiting for my friend to lend me a computer to test her
Old Aug 16, 2010 | 01:56 PM
Car: '92 Camaro
If you haven't already, test to make sure your injectors are firing. Easiest way is to crank the engine a few times, then pull one of the plugs and check to see if its wet with gas. psi at the rail only shows the fuel pump as ok
Old Aug 16, 2010 | 06:09 PM
Car: 89 gta
brill thanks for the help will be giving that a go tomorrow or wednesday if i dont have time
Old Aug 18, 2010 | 02:23 PM
Car: 89 gta
she works at lasted bloody thing
ended out to be wet plugs whipped out 5 that i could get to and they were covered in fuel dried them of put them back in and of she went
thanks for your help guys
http://www.youtube.com/watch?v=oZ4sro3kUNo
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
