vaccum leak at injectors?
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
anyone have this problem or have resolved it. car idels at 1100 and jerks when taking off. sprayed some starter fluid and there is deff a leak. not sure how to fix it. it is a holly stealth ram setup. thanks for the help.
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Re: vaccum leak at injectors?
Only time I had a vacuum leak at the injector turned out to be the "O" ring on the injector. It didn't allow fuel leakage but it did allow air to get sucked in. New "O" rings solved that.
Jake
Jake
92projectcamaro
Jan 18, 2016 08:00 AM
ramicio
Sep 6, 2015 11:25 AM
