IAC Problem?
Old Aug 21, 2010 | 09:06 AM
madmax87's Avatar
IAC Problem?
87 Iroc, 305 TPI. When driving the car for awhile, when I come to a stop with my foot on the brake, the car will creep to a faster idle. It will usually go from around 700 to 900. Car runs fine and doesn't throw any codes.
Also if I shut the car off and engine temp is still hot, when I restart it, it acts like its cold. Engine rpm goes to around 1300 and then comes down after about 30 secs. Does this sound like a typical IAC problem?
Thanks as always!
Old Aug 21, 2010 | 05:24 PM
alexisgreene's Avatar
Car: 91 Camaro RS
Engine: 305 (L03)
Axle/Gears: Stock
Re: IAC Problem?
You could use a DMM to check the voltage across the IAC at idle to get an idea if it is the cause. Vacuum leaks and fuel pressure fluctuations could also be a cause of what you describe. Your idle rising for about 30 seconds before returning to normal, that sounds like your ECM is compensating to correct the issue. I would start with a vacuum guage after looking for any visible vacuum leaks.
Old Aug 21, 2010 | 07:09 PM
madmax87's Avatar
Re: IAC Problem?
Thanks for the suggestions. I was actually checking the IAC and found it finger tight with a home made gasket on it. I went ahead and replaced it. Pulled throttle body apart and throughly cleaned. Not much better. The car does have a Hypertech chip in it.
Were are you suggesting to hook up vac gauge? What is a typical reading for this engine at idle?
Old Aug 21, 2010 | 07:28 PM
Car: 91 Camaro RS
Engine: 305 (L03)
Axle/Gears: Stock
Re: IAC Problem?
A normal reading depends on your engine config. When I had mine, I installed an aftermarket vacuum gauge where my A/C controls used to be so I could always monitor it. A stock reading should be somewhere close to 20 inches. As to where to hook up a hand gauge, thats up to you. You can tee into a vacuum line or unplug a line from your TBI unit (not the one going to the MAP sensor) and plug in there. I recommend the one going to your cruise control.
It is good you found the problems with the IAC. If it was finger tight with a homemade gasket, it is a strong change that it may be the source of your rough idle. Use a DMM to see how it behaves while the engine is running on and off idle. Is your engine light on?
Old Aug 21, 2010 | 09:38 PM
madmax87's Avatar
Re: IAC Problem?
Didn't throw any codes. Actually the engine idles fine, not rough at all. Just creeps up. I know the SES is working as it threw a VSS code a month ago when my speedo cable broke. I took it for another ride today after the IAC replace and it still creeps up a couple hundred rpm's. Would a TPS have any inpact on this? On the IAC, what voltage am I looking for across what pins at idle.
Fuel pressure looks good and stable
Thanks again for your help...
Old Aug 21, 2010 | 11:07 PM
Car: 91 Camaro RS
Engine: 305 (L03)
Axle/Gears: Stock
Re: IAC Problem?
I dont have the wiring diagram at this moment but I will post an answer to that question later once I dig up my manual. Pretty much you want to see if the IAC is actually functioning the way it is supposed to, and if the ECM is intentionally raising your idle speed. From what you have said so far, I strongly believe your problem is some type of vacuum leak. Try to get a vacuum reading asap. You should have a reading between 18-20 inches at idle, the higher the better but definitely not lower.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
db057
Sep 4, 2015 07:57 AM
greenyone
Sep 2, 2015 03:39 PM
86IROC112
Aug 21, 2015 07:20 PM
