Throttle Valve Problem????
Old Aug 21, 2010 | 10:16 PM
garmo1's Avatar
Car: 1992 Camaro Z28
I've got a 92 Z28 with an auto. trans. that has been driven only about 1000 miles per year over the past 10 years...got 91000 miles on it. Recently, I started having a problem. When I start it and head down the road, the trans. seems to not want to shift into 2nd....RPMs don't jump. After about a few minutes of driving, it shifts into 2nd....no problems after that until the next cold start when the same thing happens. Is this a sticking throttle valve?
Old Aug 21, 2010 | 11:12 PM
alexisgreene's Avatar
Car: 91 Camaro RS
Engine: 305 (L03)
Axle/Gears: Stock
Re: Throttle Valve Problem????
90% of tranny problems can be solved by replacing the fluid and filter. Try doing this and see if the problem goes away, gets worse, or stays the same. Check the filter/fluid for metal particles as well.
Old Aug 22, 2010 | 02:30 PM
garmo1's Avatar
I replaced the trans. fluid and filter about 7 years ago....driven about 7000 miles since. I had the fluid flushed a few months ago (no new filter).
Old Aug 22, 2010 | 03:58 PM
Car: 91 Camaro RS
Engine: 305 (L03)
Axle/Gears: Stock
Make sure you have no vacuum leaks. Check vacuum source and make sure your throttle cable is properly adjusted. I would begin looking at the governor and valve body. Check for any visible damage or any possible sticking. That would also be the perfect time to add a new filter on as well. You might want to test pressures before doing this.
92camaroJoe
Jul 29, 2023 07:57 PM
lakeffect2
Aug 23, 2015 08:44 AM
perZ
Aug 15, 2015 01:17 PM
92camaroJoe
Aug 13, 2015 06:07 AM
