BBC Broken Rear Main Cap Question???
Car: 1983 T/A
Engine: 454 BBC
Transmission: Built 700R4
Axle/Gears: Weak 10 Bolt/3.23
So while recently replacing my oil pan gasket, I was inspecting my crank when I found that my rear main cap has a broken corner exposing the oil pump shaft. I purchased a set of caps to replace the broken one. A buddy of mine suggested that I needed to take my block to the machine shop and have it line honed if I was going to replace the cap or else I would get uneven bearing wear on the new bearing. Here is my question, If I replace all of the bearings, will I still need to get the thing honed or not. I figure there has to be someone out there with some machining experience. I'd rather have a second opinion before tearing the thing apart. Thanks!!!
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: BBC Broken Rear Main Cap Question???
Absolutely you need machine work if you're replacing caps.
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The only way to ensure the new main cap is true to the webbing and inline with the others is to have the block line honed. If you don't get the machine work done, you'll toast the bearing and cause more damage than the machine work will cost.
1992 Trans Am
May 10, 2023 07:19 PM
There really isnt any debate on this. It 100% has to be done.
