stroker clearance ?
Old Aug 25, 2010 | 10:11 AM
86z89iroc's Avatar
Car: 86 z28 daily, 2 89 iroc-z's
Engine: sbc's
stroker clearance ?
ok i have the powerhouse 335 stroker kit and a comp cams 269 xfi computer cam in 89 305 tpi block. will i have any issues for clearance? and if i do how do i go about fixing them?
Old Aug 25, 2010 | 10:52 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: stroker clearance ?
The only way to see if there are clearance issues is to test fit the assembly. If there are rod-to-block issues, you can grind the block. If there are rod-to-cam issues, you may be able to clearance the rod very slightly, or you may need to replace the rods or use a small base-circle cam.
Old Aug 25, 2010 | 10:58 AM
383tpimachine's Avatar
Car: Corvette
Engine: 383
Axle/Gears: D36 w/ 3.08
rotate the block with a big ratchet. If you feel it get stiff back it out and inspect where it hit. Grind where necessary.
As for the cam im running the XE270 and had no issues with my 383 but you never know until u spin it.
Also put the oil pan on and inspect for issues there aswell
Old Aug 26, 2010 | 09:50 AM
86z89iroc's Avatar
Engine: sbc's
i made a call last night and was told that .535 or more lift then you start to have clearance issues.
Old Aug 26, 2010 | 10:58 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's not true, it's the duration that's more of an issue, not the lift.
Old Aug 26, 2010 | 03:16 PM
86z89iroc's Avatar
Engine: sbc's
i called powerhouse last night and that is just what the guy said. i really dont know. thats why i asked.
83RDRACR
Mar 26, 2016 08:13 PM
Nervous2
Oct 8, 2015 10:53 PM
91 SrS
Oct 7, 2015 04:32 PM
Chevykid810
Sep 28, 2015 12:57 PM
JSDaddy189
Sep 26, 2015 03:50 PM
