what motor do I have??
Old Aug 25, 2010 | 10:30 AM
my84camaro's Avatar
85 firebird trans am.5.0,the vin says its a tpi but it has a rochester carb on it.the motor seems to be stock
Old Aug 25, 2010 | 10:56 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: what motor do I have??
It could be just about anything. Check the block and head casting numbers.
Old Aug 25, 2010 | 11:04 AM
my84camaro's Avatar
why does the vin say its a 305 tpi?
Old Aug 25, 2010 | 11:33 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
25 years ago it was.
Old Aug 25, 2010 | 12:18 PM
my84camaro's Avatar
but it all looks original.where are the body tags on the car?
Old Aug 25, 2010 | 12:49 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It could very well be all original, just not to that car.
Old Aug 25, 2010 | 04:04 PM
Big Cleatus's Avatar
Car: '84 Trans Am
Engine: 350 Carb
Axle/Gears: Stock but subject to change.
If your VIN says TPI then your car use to be a TPI. Someone could have either done a TPI to carb swap, or more likely a whole engine swap. Probably just took a whole stock engine out of something else, that would be why it looks all stock. Check the casting #'s and you'll find out what motor you have.
Old Aug 26, 2010 | 07:47 PM
my84camaro's Avatar
block number 14010201.says its a 80-84 305..could this be the stock motor for my 85 ta?
Old Aug 26, 2010 | 08:35 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It could be the stock block, but the engine's been altered.
Old Aug 26, 2010 | 08:48 PM
my84camaro's Avatar
well I'm just wondering if its a 84 and the vin has been changed but it has all the body marks of a 85.the intake does have some jb weld on it.could the motor be a lg4 from late 84 and the vin be wrong?how else can I find out if the numbers match.
Old Aug 26, 2010 | 08:49 PM
my84camaro's Avatar
the vin plate has been rotted off and the number I have is from all the previous owners.
Old Aug 26, 2010 | 08:51 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Check the cowl tag on the radiator support, see if you can find the last 5 digits of the VIN they gave you.
my84camaro's Avatar
the vin is 1g2fw87f6fnxxxxxx.maybe I'm reading it wrong?
Old Aug 26, 2010 | 08:52 PM
my84camaro's Avatar
there is no tag on it,unless I'm blind and cant see it..where would it be?
Old Aug 26, 2010 | 08:58 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Right on the radiator support near the hood latch, IIRC. It was only present through 1985, you might have a later car.
Old Aug 26, 2010 | 09:16 PM
my84camaro's Avatar
nothing there and dont look like there ever was
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
madsv1000
Aug 20, 2015 06:45 AM
slade5612
Aug 11, 2015 07:19 PM
