85 camaro rear main seal
Old Aug 27, 2010 | 01:00 AM
steves85's Avatar
Car: 85 Camaro
Engine: 305 carb
Transmission: 700r4 soon to be a t5
have trans out of a 85 camaro how do i replace rear main seal
Old Aug 27, 2010 | 01:25 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 85 camaro rear main seal
Drop the oil pan, remove the oil pump, remove the #5 rear main, snake the block-side half of the seal out around the crank journal, push the new block-side seal in (specialized plastic tools for removal and insertion are available) and replace the cap-side half staggering the ends so they don't align with the cap-to-block parting line, reinstall the #5 rear main with a small amount of RTV in the corners and a tiny amount on the seal-ends, reinstall oil pump, replace the pan.
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reborn756
Sep 4, 2015 03:42 AM
Exxon Limited
Aug 9, 2015 08:13 PM
Leggman1
Aug 6, 2015 04:15 AM
