POLYLOKS
Old Aug 30, 2010 | 02:24 PM
usmc949803's Avatar
Car: 92 Camaro RS
Engine: 77' 350 bored 355 Holley carb
Transmission: Turbo 350
POLYLOKS
ok im lost on this. just put polyloks on. tighteen down to zero lash. do quarter turn more (same as always did on this motor) tighten set screw and lash comes back......
Old Aug 30, 2010 | 02:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: POLYLOKS
Turn the set screw together with the nut for the last 1/8 turn.
Old Aug 30, 2010 | 02:46 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Re: POLYLOKS
Also, be sure the lifter is riding on the base circle of the lobe when you find ZERO lash. That's the part that many guys get tripped up on.
Jake
Old Aug 30, 2010 | 02:51 PM
usmc949803's Avatar
Car: 92 Camaro RS
Re: POLYLOKS
yeah ive set them before with no problem when i was using the regular nuts but they are worn so switched to polyloks now having this problem
Old Aug 30, 2010 | 03:09 PM
JakeJr's Avatar
Axle/Gears: 3.07
Re: POLYLOKS
Right.
Lifter riding on the lobe's base circle, set preload amount of your choice (I use 3/4 turn), tighten Allen head set screw with an Allen wrench, THEN tighten the entire poly lock assembly giving it a tad more of a turn by turning the hex head to lock everything in place. Done that way it won't loosen.
Lifter riding on the base circle (heel) is the key. If the lifter is on the cam's ramp you're not getting the preload you think you are.
Jake
Z28NZ
Jun 25, 2012 03:44 AM
Z28NZ
Mar 7, 2012 05:27 PM
