A/c Compressor help
A/c Compressor help
hi.i purchase a 82 trans am and the compressor belt is not installed.i was wondring if anyone have any diagram where ishould route the belt in the engine or a picture where i can see where is it routed.thanks in advance.
oh yah engine is v8 5.0.and its a 4 bbl carb.
I dont have much experience in the car and I need the A/C system.the compressor is not hook up with a belt.i dont know how this will work so pls any help is much appriciated.thanks
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: A/c Compressor help
which compressor do you have?
ok. i would go to a salvage yard and get the necessary brackets to run a new harrison compressor.
@dan, hi thanks for your advice.I kinda wonder also if that is the case.but for some reason when i got this car,the last owner dont want the a/c...now the belt that is has right now is just an exact fit without getting routed to the compressor.so i figure that the compressor should have its separate belt...do i have to buy a new belt thats longer to fit it?can you provide me a diagram what should it be so i have a clue?pls let me know.thank you very much for your help
Car: 1984 camaro Z28
Engine: 355 SBC
Transmission: 700 r-4
Axle/Gears: Strange 3:73 posi
yeah 2 belts accually go around the power steering to the fan one is just ps to fan one is ps, fan, a/c.
Car: 1984 15th Ann. T/A
Engine: 350 Goodwrench
Transmission: T5 (Not factory, possibly rebuilt)
I have the same problem, when the engine in my 84 T/A was swapped out they didn't reinstall the AC system, so the compressor is long gone. Since you're using the old v-belt/drivebelt setup from before they added serpentine belts, then a smaller belt will be used along with the larger one that goes to your water pump,crank, and alternator. At least, that's how mine is. My car has 2 belts at the moment, one for the power-steering by itself to the crank, then the water,Alt, crank is a different v-belt.
Hope these responses helped any.
EDIT: The only difference with mine is I have an electric fan, so my v-belt setup may be different from yours. Just a forewarning.
Car: 1982 trans am
Engine: 4bbl carb 305 v8
Transmission: 3 auto
Its an old thread but will take a shot and describe my situation. I got another 82 T/A. I got a ac compressor harrison unit but not 113119 which went with LU5 put another one with id 1131198.
I had seen this part no to 82 corvettes and 82 firebird S/E.
Is there any other difference between these 2 models?
2012sergen11
Oct 13, 2015 07:38 PM
