Are the AFR#8002 springs to much for hydraulic roller lifter?
Old Aug 31, 2010 | 05:51 PM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
So i just got some new AFR 1040s that were ordered with the AFR-8002 springs and i have been told they might be to much for a hydraulic lifter unless i spend a grip and get something like Morel lifters. I dont really want to pull the springs and get others since everythin is setup and brand new now. These will be goin on a built 356 with a 224-230 .57s lift cam. The motor now has a smaller comp cam with im guessing comp cams lifters....anyone know if the lifters i have will work fine? If not what should i do...i have been told i maybe could run the LS7 lifters?
spring specs. #8002
http://www.airflowresearch.com/valve_spec.php
87v6Bird
Jul 1, 2018 04:12 PM
codeysabatini
Nov 10, 2015 04:07 PM
Jorlain
Oct 8, 2015 01:57 AM
RyanJB
Sep 14, 2015 03:39 PM
dimented24x7
Sep 6, 2015 03:51 PM
