What could be causing this?
Old Sep 1, 2010 | 09:22 PM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
My engine is running pretty sluggish and really rich. What could be causing this? Have a friend whose dad says he could help me look at it and see what could be wrong but I was hoping to compose a list of things that could be wrong so he has an idea of what to look for. As sig says I have a 5.7L 350 V8 that is completely stock and has 22,000 on the rebuild.
Last edited by '87IROCZOWNER69; Sep 1, 2010 at 09:36 PM. Reason: forgot some stuff
Old Sep 2, 2010 | 12:10 AM
alexisgreene's Avatar
Car: 91 Camaro RS
Engine: 305 (L03)
Axle/Gears: Stock
Re: What could be causing this?
There are many many things that cause you to run rich. Faulty ECT, faulty O2S, faulty MAP, leaking injectors, high fuel pressure, faulty ECM, faulty IAT, dirty air filter, exhaust leaks, even vacuum leaks. There are so many things that can contribute to a rich condition in fuel injected engines.
HoosierinWA
Oct 7, 2015 10:15 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
mfp189
Sep 27, 2015 09:25 AM
