another ignition key buzzer question
Old Sep 7, 2010 | 10:13 AM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
What triggers the key buzzer noise you're supposed to get when you turn the key to the on position? My first thought was oil pressure, but I've got the sensor plugged in and thats not it..
I've finally got the car back together to a point where it should run, but the key buzzer noise is noticeably missing. I'm thinking I missed plugging in a connector somewhere.
Old Sep 7, 2010 | 10:34 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: another ignition key buzzer question
Interior light come on when you open the door? I thought they were a part of the door opening in some respect.
Also, if I remember right, the buzzer goes off anytime the key is in the ignition - like a warning that you left your keys in the car - but that may only have been when the door is opened as well.
FYI the door jamb switches make a ground connection when the door is opened.
Sorry I don't remember better - Ive taken my buzzer module out as it drives me crazy - it's under driver dash, about the size of a pack of cigareetes, just plugs in.
Old Sep 7, 2010 | 10:39 AM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Supposed to come on when the key is off, and the headlights are on, also when the key is on, and the door is open. I think thats it, though.
Old Sep 7, 2010 | 10:57 AM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
I'll have to connect the headlight harness and see if thats whats causing it.
Old Sep 7, 2010 | 12:35 PM
Yeah, if they aren't hooked up, maybe that will cause it not to buzz.
Let us know
Old Sep 13, 2010 | 08:46 AM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Found my answer this weekend. I was looking in a box of parts from under the dash that I removed and saw a little black box that looked like it had a small speaker in it. Found out where it was supposed to go in the service manual, plugged it in and now the key buzzer is back.
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
